Poloroid 42 in tv does not stay on will stay on for awhile bu then it shuts its self off then it has to cool off and be plugged back in this model number for the tv is pla-4237
SOURCE: Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to [email protected]
SOURCE: Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
SOURCE: magnavox 26mf23id/37 will not stay on
Replace capacitors 2079 and 2080 with 1000 uf, 50 volt caps. They are on the power PCB at the top as you look at the unit from the rear. Barneyluc.
