Well here are some 'repair' kits so you are not the only one friend !
http://www.powerwash.com/cleaning-supplies-and-accessories/spray-guns/spray-gun-repair-kits/mtm-hydro-trigger-spray-gun-repair-kits.html
Perhaps give them a call about yours ?
SOURCE: Kirby Ultimate G carpet shampooer not producing foam anymore
I was having the same problem. There is a filter plug that came loose on mine and went down into the hose. It belong on the water tank and fits in there tightly and the hose end goes over it. That's what actually makes the foam.
SOURCE: pressure relief valve opens
Hi.
If the hose works ok then you have A blockage in the section of the machine that goes from the brush roller to the wastebin.
Just remove the soleplate under the machine & check all the airways working back to the wastebin. definately check removeable inspection ports you will probably find omething in them blocking the airway.
http://dysonmanuals.llc.nu/
SOURCE: Foam stopped working on my Kirby shampooer
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose.
Marci
SOURCE: carpet cleaner wont foam up
My educated guess ot that the little suds screen is not in the hole on the tank where the hose plugs into it. Check to see if it is wedged sideways in the end of the shampooer hose. (this happens (OFTEN)
Here is a link to my online shampooer manual in case you need any more instruction...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
