Question about Sew D'Lite Sewing Machines
My Aunt gave her D'lite sewing machine. It sews correctly but will not stop sewing unless you unplug the cord. The start and stop button will start the sewing if not using the foot pedal but it will
This machine stitches fine but will not stop stitching unless you unplug the foot pedal cord. The start button starts the sewing but the stop button being pressed does not stop the stitching
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Sew D'Lite Expert
  • 631 Answers
There's a possibility that your foot pedal is sticking; if that is the case, it's probably overriding the stop button. See if you can take the cover off and clean it using alcohol, and leaving it open for a couple of hours to make sure it has dried. Visually check the wires while it's open, too, to see if you can see any fraying, and make sure the plug on the machine side is firmly seated in the machine.
Posted on Sep 14, 2014
3 Suggested Answers
Anonymous
SOURCE:
advacak
Denny Adams
  • 125 Answers
SOURCE: Machine stops after 2-3 stitches
open your bobbin case and un jam it thread wound around the center
Posted on Dec 02, 2008
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Posted on Jun 12, 2011
My aunt just gave me this Baby Lock Pro Line Serger BL4-738D 4 Thread Is this a good machine.
Baby Lock is a very good serger. Have you ever used one before? If not, be sure to read through the manual carefully before you try to use it. They're not just like other sewing machines. Enjoy.
Apr 17, 2015 | Baby Lock Sewing Machines
Don't know what the blue buttons on Sew D'Lite are for.
The top one with the bobbin on it is for winding a bobbin. When you press it the bobbin winder spins around. The bottom two are for if you don't want to use the foot pedal. The second of these two, which has a O/I sign on it, makes the machine stop and start. The one with the snail and the rabbit controls the speed.
Sep 24, 2012 | Sew D'Lite 11401 Mechanical Sewing Machine
Sewing machine stops sews a minute slows down or stops then starts up
I suggest having the machine checked at a sewing machine shop
to see if there is something wrong with the motor, or the foot pedal
but first check to make sure the power cord & foot pedal are
connected correctly
Aug 20, 2012 | Singer Sewing Machines
Hot to stop a a previous transmition
If you don't have the transmission box up with the "Cancel" button up, then there's a few steps you have to take. First, close the software on your computer. Next, turn of the sewing machine. Unplug the USB cord both from the sewing machine and from the back of your PC. Now plug the USB back into the computer, then the sewing machine & turn the machine back on. Finally, reopen the software. This should clear the "buffer" between your computer and the machine of the pending transmission. I've had to do this every time I have a finished design before I can start a new one.
Feb 23, 2011 | Singer CE-100 Futura Computerized Sewing...
Start/stop button problem will the machine run on its own
You have to unplug the power cord to the the foot pedal. The manual doesn't include this. And good stinkin luck with Sears or Kenmore customer service! Just pull the cord out of the machine and the start/stop button will work. Try it on a slower setting at first though. Also, if you need additional presser feet, Singer, Brother, Janome, and possibly other brands will usually work as long as they are the snap on type. I really do like my machine, good luck with yours!
Apr 23, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Start/stop button is not working.
When you have the embroidery unit connected to the machine, you must have the foot pedal cord disconnected. Then it should work. As for using this machine for normal sewing, yes, it is supposed to do that. Unless you get a lemon like mine. It lost reverse, and only takes long stitches. Hopefully your luck is better than mine with this Disney "thing".
Jan 19, 2009 | Yamata FY101-1A
Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
Jun 16, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
76 people viewed this question
Top Sew D'Lite Sewing Machines Experts
Renee Knafel-Bullock
Jimmie Sill
Are you a Sew D'Lite Sewing Machine Expert? Answer questions, earn points and help others
