My Miele S4211 would not switch on so I changed the power switch. The new power switch was working perfectly when I tested it prior to reassembling the vacuum cleaner. When i first reassembled the vacuum it would not switch off now it won't switch on. It's almost like the outside switch is not connecting with the power switch.
Www.mieleusa.com/Service
Most likely problem one of the wires leading to the switch. Ohm them out with a OHM function of a multimeter, while unpluuged , of course. .
Sorry for the delay in responding to your suggestion but i didn't receive any notification that you had left a message. Could you please explain a little more about using the OHM Meter?
Thank you I will take a look.
