Westinghouse TV code model LD-4655VX
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: I initially used a code
Hello Nicolelc1234, I can help you set your TV up live, please send me an email to [email protected] so we can go ahead and set that up.
SOURCE: westinghouse LD-4655VX, my remote cannot tie in with cox codes..help\
Other than Google to search for additional codes the COX remote may just not be capable of this brand.
Westinghouse is a name sold and the sets (I had heard they are out of business) all use specific and different codes---means if the remote is lost/broken you are out of luck without it.
SOURCE: Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
It's likely a loose solder connection that acts up after a short warm up period or defective capacitors on one of the circuit boards.
SOURCE: Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
