When unit is on the volume is loud and cannot lower it or change it. Only way to watch TV is turn surround off and putting volume on TV. Not sure what connection is off; tried changing audio settings in TV and could not find solution.Thank you in advance
SOURCE: loud humm. I have to keep the volume down when watching the TV.
A humm may be caused by a cable TV grounding problem called a "ground loop." Basically, the grounding for the Cable TV line and the power outlet for the TV are at unequal levels. I had this same humm with both the internal TV speakers and with external speakers (headphones, etc.). The 2 solutions are (1) install a Ground Loop Isolator at the TV, or (2) call the cable company to troubleshoot the problem. I figured the time I saved dealing with the cable company was worth the $50 for the part. I installed the Jensen VRD-1FF which has worked perfectly! Ordered from eBay and saved about $12 over the Jensen Electronics web site price. Hope this helps.
SOURCE: Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
SOURCE: Bose GS 321 HDMI issue.
did you manage to fix it? I have the same problem. Would appreciate if you can share some results if you have any.
Many thanks, Jeffrey [email protected]
SOURCE: I have the Lifestyle V10 Home Theater System. It
The Lifestyle V10 has a remote that uses RF code to communicate with the receiver. That means it uses Radio Frequency which could be a problem if you have too many wireless devices or radio's around. Check if you have any Cell phones, Cordless Phones , Wireless Routers etc which emit a Radio frequency which would cause it to be erratic as there would be a conflict in the signals.Try to move them away from the receiver.
Volume/Mute Indicator: This
indicator will glow green when the
HK3270 is turned on. Its position
will enable you to judge the relative
volume of the unit even when the
speakers are muted or turned off.
When the indicator is pointing
towards the left, at an "8 o'clock"
position, the volume is low; when
it is pointing to the right, as in a
"3 o'clock" position, the volume is
loud. When the unit has been muted,
pressing the Mute button ïâthe
indicator will flash
