ensure that the supply line is clear. shut angle stop valve off and remove line from bottom of tank place line into a pail and open angle stop valve, if clear water will flow quite readily. if not replace line. the fill valve is available at home depot. personally I would replace toilet with a quality American Standard. if your toilet is not a Glacier Bay good luck finding repair parts.
the amount of water in a pan is set by the height of the bend at the back
If you are asking how to get more water to flush the pan, raise the water level in the cistern by adjusting the water control height in the cistern
If it has a fluid-master assembly, there's a metal bar on the side of the float with a small metal adjusting tab on it, squeeze the tab together and raise or lower it on the bar to change the float setting.
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Try adjusting the water level down about a half inch or so and see if that helps. It could just be siphoning. Otherwise the valve may be defective. Hope this helps.
