I had to purchase a universal remote and need the code to operate the tv
0250,0261.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
SOURCE: Need to find code for RCA universal remote,
Go to
http://rcaaudiovideo.com/
On the left side select 'remotes' and then your remote type. You will be able to download the manual and codes for your RCA Remote Control.
Let me know if you have any other questions. Please rate this solution. Thanks.
