Pioneer CDJ-800 Turntable Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CD BACKSPIN the unit backspins ok on vinly mode but when you put it on cd mode nothing happens
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
184
Points
I agree with solution 1...as it says on the button cd mode...so its not possible to do spinbacks in cd mode only in vinyl mode (emulating an actual record being played/spun back/scratched)
Anonymous
Level 2:
  • Expert 515 Answers
  • Posted on Aug 30, 2009
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
292962
Points
647
CD Mode does not react in the same manner as as Vinyl mode when you try to back spin. At the very least, you will only be able to go back a few bars. It's mainly used to set the Cue properly.
If you want it to back spin, you'll have to use the Vinyl mode.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Futura Quartet embroidery thread breaks
first unthread completely the machine and rethread it checking all the places run smooth. Change the needle for a new one with the correct size for your fabric and project. Clean the bobbin case and surround areas with a brush making sure is neat and no any fluf left behind. Put a fresh feel bobbin and try again. Sure will do the trick and will run perfect again. Happy sewing!!!!!
1helpful
My CD drawer is stuck and has caused the complete unit to shutdown. Digital display reads : ' DRAWER ERROR '. How do I get things up and running again ?
ok i had this same problem happen to me this is what i did to Fix the problem.
i fully shut down the computer removed the power cord from the CD player and reinstalled the unit also make sure nothing is in the CD player.
if this doesn't work give me some more info on how this problem happened.
1helpful
Radio works ok, nothing from the cd player its like there is no power to the unit, nothing happens when you insert a disk or press the disk button just dead, any ideas. cheers Nick. ps its a standard...
If the radio works but the CD player doesn't it's something internal to the unit. The radio and CD player get their power source from the same wire that goes into the unit.
8helpful
4answers
How to use Audioline Pro DJ Multimedia Mixer M Dex 3.0
I have been recently using this Cd Dj deck at parties and have some general knowledge of the product, it has alot of potential. Is there anything in particular that you need help with? Or is it the general concept of using them.
Currently, i don't think there are that many websites that explain how to use the Cd decks, however i can provide you with some basic information. Most of the information here could be worked out by trial & error.
- Pitch control on the right of each cd deck can be slid up ( slows it down %) and slid down (speeding the track up %) i think the pitch control has a range of either +-10% or +-16%.
- Cue button, has the potential for Cue'ing or setting up the cd to instantly jump to the "cue'd" point with the press of this CUE button. This is done by either pressing play/pause button and rotating the jog wheel to a point of time in the track which automatically sets the cue point OR holding down the >> or << search button to find a spot within the track at a greater speed.
-Vinyl mode. Pressing this button will set the deck to the "vinyl mode" to simulate scratching or even backspins. pressing this button again will change the mode back.
- the Crossfader (or 'X' fader) button will select the left cd track if the x fader is all the way to the left and the right track if the x fader is all the way to right. having the X fader in the middle will play both tracks together.
- Low, Mid, High. These nobs on the middle section of the deck change the individual track by which it is corresponds. (Left side = left cd track, and vica versa) Low refers to the Bass of a track which can be essential for mixing two tracks and elminating excess bass noise. Mid refers to the drumming and even synth of a track, and changing this can result in some cool sounding effects. High refers to the 'high' frequencies of the track playing, such as snares, hi hats and possibly vocals. All these controls are crucial to understand in order to mix 2 songs together successfully. It's good to get a chance to muck around with these cointrols. The middle of each control resets the setting to normal or default.
- Channel fader. the two controls that slide up & down on both sides of the mixer on the deck. This is also referred to the volume setting. Useful for mixing seamlessly one track into another.
- Gain. This control at the top of the mixer refers to the volume level or 'gain' of the cd track that it corresponds to.
- Jog wheel. Serves 3 purposes. firstly it can be used whilst a song is playing to temporarily speed up or slow down the track to match with the song on the opposite side. secondly, whilst holding down the 'search' button, operates as a control to quickly find a spot in a song. and lastly when selecting "vinyl" mode, can simulate the reaction of a vinyl turntable. The scatch function, and backspin effect.
- The pitch button, is just another control to speed up or slow down a song temporarily whilst holding down the '+' or '-' button.
- Reverse button, for a certain amount of time will play the song on the left or right in reverse.
- Time. this button is essential to change the time selection on the cd deck, to either "Time elapsed", "Time remaining" and "total time remaining on the cd".
- the "tap" button, allows the user to physically "tap" the button in time with the song's beat, which calculates the Beats per Minute (Bpm) of that song. which is essential to work out the bpm of 1 track to mix the speed with that of the opposite deck.
- Cd/usb/sd, changes the mode of system reading. from CD to USB or SD card.
I really hope this general guide to using the Audioline ProDJ MDex3 has helped!
Peace. Marc.
Apr 03, 2009 • Music
2answers
When i backspin the arm is forcing itself off the vinyl
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Kenwood kdc-c710
It sounds like a blown fuse to me, or problems with the power to the player. Check all connections and power to the unit.
Take special care to make sure you know where the unit gets power from, it could have more than 1 fuse.
Regards
Philip
1helpful
Tone arm skip back.
You most likely have broken balls,,, lol yes balls bearings are most likely broke you might have to replace your arm.. about 80.00 for the part
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
