What should i do please help me out
SOURCE: pin code blocked
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1)
If you still have your packet that your Sim Card came in, you should
find your PUK number in there, if you don't have the packet, please
read bellow.
2) You must get a phone that is on the same network
as your phone and call the networks Customer Care and ask them for your
PUK number, they will ask you for your phone number, then they will
tell you your PUK number. Once you have done this, you will be able to
reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
SOURCE: PUK code for NOKIA 6020
Your nokia 6020 doesn't have problem. It's your sim card. If you still have your simcard packaging, the PUK code is written their inside it's brochure. Or you can also go to your mobile phone network and ask its PUK code. Or simply buy a new simcard with the same network company. Thank you
SOURCE: nokia xpressmusic pin blocked enter puk code
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
SOURCE: nokia e71x pin code blocked , enter puk code
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Thank you for using FixYa!
Rate this solution
SOURCE: PIN blocked.Enter PUK code.
PIN blocked.Enter PUK code IMEI :351869043115763 please help me out
