Turned off the braker. Put it back on. It showed normal cycle, after 10 seconds the FO error message came on again
Hello Ermellina, thank you for your post!
If you are getting an error code "F0" on your Frigidaire dishwasher, it usually means that you are experiencing an issue with the water level. To clear the error code, you can reset your dishwasher. However, since you have already turned off the circuit breaker, at this point, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis. Best - Z
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
SOURCE: Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
SOURCE: Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
SOURCE: LG DWLD4080T dishwasher shows HE error message
"HE" is a "HEATER ERROR"
These are the possible causes for "HE" error:
1. The Circuit of Heater is troubled.
2. The Thermistor is troubled.
3. The Heater is shorted.
4. The Relay Circuit is troubled.
The Possible solutions are:
1. Repair the Circuit of Heater.
2.Replace the Thermistor.
3. Replace the Heater.
4. Repair the Relay Circuit..
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
