Question about Video Game Consoles & Games
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
All of coloured AV cables are in and both the xbox 360 and tv cable are in correctly (tested the xbox on another tv and it worked fine). Why does the xbox 360 not get picked up on by the tv and what settings/channel should it be on in order to work correctly? Thank you
  • 20 Answers
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Posted on Sep 14, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: Xbox 360 has sound but no picture on HD setting
Well myxbox was working fine then the colors went crazy, i was play GTA San Andreas on my 360 and the yellow bled everywhere, i wiggled yellow colored cord (video) and still was ditorted, so i turned off and on my 360 and i got diagnol dotted lines with sound, but nno picture..
I tried everything only thing that worked was the towel trick. type in 'towel trick' on youtube search. very simple technique
Posted on Apr 08, 2008
derek martin
  • 148 Answers
SOURCE: Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Posted on Jul 11, 2008
Anonymous
  • 7 Answers
SOURCE: AV Cable Problems for PS3
I am not completely sure that this will help you, however try doing a "factory reset".
You accomplish this by first (1) having the PS3 being off (2) hold down the power button on the front of the PS3. It will beep once when you turn it on and then a second time. When you hear it the second time, let go. See what happens.
Sometimes if you connect your consoles video a different way such as S-Video, Component or HDMI, your console remembers those settings and saves them causing many individuals to turn their console on and there is no video.
I hope this gives you somewhere to start.
Posted on Dec 30, 2008
Anonymous
  • 31 Answers
SOURCE: No picture on TV when Xbox 360 is turned on
For the most part, an XBOX will display a picture on the TV regardless of what the settings are. If there is no picture, it is most likely the cable or the XBOX output terminals themselves.
Since you have said that your friend's AV cable didn't work either, even though it did on his, we must assume that the problem is with the XBOX.
 If the warranty is still on the console, call Microsoft and send it in. If it isn't either call Microsoft and see that they can do, or find an online repair shop that can help you.
If you need furthur assistance, feel free to ask. If this response helped you, please rate it!
Thanks!
Posted on Apr 13, 2009
Anonymous
  • 1093 Answers
SOURCE: Xbox 360 not sending audio/video signal.
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Posted on Jan 26, 2010
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
XBOX 360
How to Connect XBOX 360
This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
Now you are ready to play.
Sep 06, 2008 | Microsoft Xbox 360 Console
Hi, i have had a old tv for quite a while now and my xbox 360 played ok on it. i have recently just bought a brand new hd tv and the colours on the sceen are incorrect for example, when i play call of duty...
look on the back of the tv you might have the av cable mixed up you have to have them right to get the right colors oather wise try adjusting the colors on the tv but i would try the cables first
Jan 27, 2011 | Microsoft Xbox 360 Console
Xbox 360 plays sound but no the video
try another tv to ensure its your xbox and not tv input. also look on your av cord there is a small switch on it make sure it is in the proper position hd or tv.
May 01, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
85 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
