SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
SOURCE: My treadmill (Nordic Track EXP3000) was working
In some cases what happens the internal switch that your key engages to start your treadmill breaks free from its bracket. Try this press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
You will be able to determine whether you can get in to this calibration mode if the key switch actually working and also at the same time it test the upper console to make sure its functional.
SOURCE: The Nordic Track machine's controls seem to be
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
SOURCE: nordic track exp 1000 treadmill console
Hii sumazone, was just wondering if you ever found out what was wrong?? I am havng same problem. thank you
You may need a controller or a new motor. Where are you located
