Cameras Logo
p
paul jacquesul jacques Posted on Sep 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Format a new sd memory card ?
I had an older memory card in the camera and I was asked to format it. Not knowing how to do that I installed a new card and I'm still getting asked to format it ?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Sep 13, 2014
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443772
Points
622693
Memory cards need to be formatted before use. Please refer to your camera manual for instructions.
Your camera may not work with 8GB SDHC cards, only with SD cards 2GB or smaller. Such cameras will report a card error and/or request formatting if you try to use an SDHC card.
If you require further assistance, please add a comment to this question and specify the model of your Kodak EasyShare camera.
5 Related Answers
Anonymous
  • Posted on Oct 27, 2008
SOURCE: FORMATTING SD 1G MEMORY CARD
I cannot get my Rollei prego da5 to format a new memory card can you help.
Anonymous
  • Posted on Apr 15, 2009
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Anonymous
  • 34 Answers
  • Posted on Jun 09, 2009
SOURCE: memory cards wont format, says card is full
Is the write protection enabled on the cards?
Which size having the cards?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
Anonymous
  • Posted on Oct 25, 2009
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Anonymous
  • Posted on Dec 22, 2009
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
How can i download using my blue dash it say memory full everytime i try...and it have a memory card which is empty and is set to download on sd card
A few things come into my mind. Are you using a card you did use before? If so, your card can't be blamed. If not, make sure you are using the right SD cards. Only a few years ago we only had MMC and SD, but with the growing capacity, there came new SD cards. These cards can't be used in older equipment. So the new cards like SDHC and SDXC need newer devices (cameras) to be able to work. They used to sell SD cards up to 4Gbyte, but now you only see 1 GByte SDHC cards. And your camera has to be compatible. I a could not check your camera, because I don't know brand nor model. Then be aware you should not format the card in any other camera or device, not even the same camera from your friend. Please try to format the card, when it is compatible with your camera. Newer cameras, made for the SDXC cards can use all SD cards.
Mar 22, 2015 • Cameras
2answers
My panasonic lumix dmc-ls75 say my pictures will go into built in memory. Is there a way to turn that off? I have an sd card in but i dont think it is picking it up. It works fine in my computer...
Go into the camera's menu and find "format"....follow the on-screen instructions to erase the internal memory. Your card should work properly after that. If not, your card may be corrupted. If so, download the pics from it to your computer and then, format the card in the camera to get it to work again.
SD card can't be read "Card Locked" is all that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
2helpful
2answers
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
3helpful
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
2helpful
2answers
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
10helpful
4answers
SD MEMORY CARD REQUIRES FORMATTING
With the SD card in the camera, turn the camera on. Go to the menu and navigate to the FORMAT command and format the SD card. For the camera to save photos to the SD card, the camera must format the card to set up the folders it needs for SAVING.
2answers
Formatting SD card
Possibly either- or Take it back to the shop and ask them to check by inserting another card or card into another camera Get which ever it is play up replaced
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
