Some have a nut that holds agitator in place. If it does, it would be under top removable agitator cap. If there is no nut, agitator snaps off by slipping fingers under agitator at 3 and 9 o’clock positions and pulling up hard and fast.
the agitator has to be pulled out manually the whole pc comes out from the bottom, place a rope or strong string under it and pull up hard. then u can remove the 7/16 nut and take off the agitator coupler or bell housing. , hope this helps
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
I would try to get clothes out, even if destroyed first. Otherwise,
there is a plastic cover cap on the top of the agitator. remove
by unscrewing or prying off. Hold down nut is exposed and remove
carefully, gently and with a ballanced pry up from underneath to raise agitator.
The most probable thing that is making that noise is a broken motor coupler if it drains but the tub doesn't move or even if the agitator doesn't move (espically the lower section) on the wash cycle the coupler is the problem. I have included a youtube video that will show you step by step how to replace the coupler http://youtu.be/9K1KHEogf3c If it does agitate let me know and ill tell you how to completly remove the agitator to check that drive block you refer to as nut under softner dispenser
Hope this helps and if it does please give me 4 thumbs up
theres nothing under your agitator, first take cover off your agitator there should be a small bolt
holding it down, take that bolt out then grab agitator from bottom and pull up it should come off easy.
it is a GE washer model #GTWN4250D1WS
