I WILL NOT LET ME REGISTER IT.
SOURCE: New Expansion Handset refuses to register with the base
On the handset, you need to go into the menu, choose register, press and hold the intercom button on the handset and the page button on the base unit at the same time until it tells you that it is registered.
SOURCE: whont work, please register in displayed on screen
To solve the register problem.... Put each phone for 20 seconds or so in the main base. I had the same issue, and resolved it this way.
SOURCE: I cannont register a ATT 2042 cordless phone to
Are you sure it's a 2042...I found 2402 manual http://www.retrevo.com/samples/AT%26T-Telephone-manuals.html
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
