I cannot gain access to the need area of Frontier's web page
No issues i share a informative links please visit and read it.. How to Reset Router Password to Factory Settings and Linksys Phone Number
Thanks,
SOURCE: Forgotten password on DG834GB router
For info if having problems you need to do a factory reset,
just pushing a pin or whatever it is you use to poke the hole at the
back of your router is just not good enough, here is the official line
quote from netgear.
Full Reset;
Hold down the reset button on the back using a paper clip, for 30 seconds with the power on.
After 30 seconds, keep the reset pressed in but remove the power lead for 10 seconds.
Then plug the power back in and keep the reset down for another 30 seconds.
So in total the reset is down for 1 minute and 10 seconds
Log into the routers web based configuration page by, launching Internet Explorer and in the address bar type
192.168.0.1
username = admin
password = password
I
was having problems with the 1.5 firmwire where the router was
rebooting it's self 2-5 times a day, logs date and time changing back
to default of 12:00 2002 or something near.
So far I have just gone back to 1.4.3 firmware which seems to work fine for a few weeks before requiring a power off and on.
SOURCE: wrt300n router won't allow 360 connection.
reset the router the make sure ur firewall is set to low if that does not work go into ur modems settings open internet browser type192.168.1.254 and go to wireless then custom services click in the box scroll to the bottom and select xbox live then u will c another page saying select host open box selxct the bottom one then click enable and try connecting again
SOURCE: The router makes a clicking noise
It sounds like you do not have a carrier, as the clicking noise that you are hearing is normal for a modem that is not plugged into anything.
Check with your ISP if you DSL has been enabled, and check the connection parameters for the dialer interface to make sure you have all the correct PVC settings, etc.
