Just moved to this house and I couldn't start the furnace. I noticed a red LED light stays on continuously. I checked fuse on board and it's okay. I don't know anything about furnaces and don't know what to do. Can you help?
SOURCE: Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
SOURCE: How to test for 24 vac between R and C
Yes you are right the control voltage of your furnace is 24 volts. Really without a load on the transformer usually runs 28 volts then you put a load on it and it drops down to 24-26 volts. Check the voltage between the R terminal and the W terminal with the selector switch in heat mode. Or move the thermostat switch to heat. R to C would do it also. You could also do the voltage check right at the transformer one side of the transformer is 120 volts and the other side is 24. Look for the black and white wires that is the 120 volt side the blue and yellow or off colors is the secondary side.
Now if it checks low say 24 or 22 your gas valve needs min. 24 volts to hold open the valve that allows the gas to flow into the burners. So if one of the symptoms is related to burners come on for about 3 to 5 min. then shut down and the fan keeps going it is loosing the necessary voltage to hold open the gas valve.
One more thing make sure the air filter is clean as this will cause the heat to build up in the heat exchanger and hit the high limit safety device and cut the gas off. Until the air cools enough to allow the high limit to reset then the gas valve will open and start the process all over again. Dirty A-Coil will do the same thing as the air goes through the coil to get to house. let me know how it goes ken
SOURCE: Furnace wont run
First of all when you flip the switch, it goes thru a startup sequence. THEN it turns on the Igniter (notice the red glow). Then the gas turns on.
Now at this point check the idiot light and it should be giving you a code of 34. That 34 (3 shorts 4 longs) says that there was a problem igniting the furnace. After it cycles thru at least 4 times and fails to ignite all the blowers, then is when you get a code 14 (1 short 3 longs)
NOTICE what's happening with ALL the burner Tubes each time it attempts to ignite. If only one or two are running....then this is your problem.
To fix all you do is take out the burner Tubes, look for debris, blow them out (blow from the front where all the jets are), and replace them in sequence from left to right (the tabs overlap).
SOURCE: I have a Carrier Weathermaker 8000 furnace. it
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Testimonial: "thanks alot i will test that."
