Like I said, this is new. Checked the cable connection- good checked the batteries- good These are very important pictures that I really need to transfer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
SOURCE: Says camera is not connected to computer
I'm assuming that you are using a Windows based machine? If so, try another computer. If the camera is recognized when you plug it in, you have a software / driver issue and it's not in the camera. Just plug the computer into any other computer and don't bother with the software.
I found this on another site. You have to set the camera itself to Mass Storage mode in order to work with Windows 2000. The steps are below. As soon as I did and plugged the camera back into the USB cable, Picture Project recognized the camera as connected, installed the mass storage driver for it and requested a restart of the PC. Able to access the memory card and download pictures.
On the camera itself, unplug the USB, turn it on and...
Press MENU....
Press ▲▼to choose SETUP...press OK...
Press ▲▼to choose INTERFACE...press OK...
Press ▲▼ to choose USB...press OK...
Press ▲▼to choose MASS STORAGE...press Ok..
Press MENU to exit...
Then plug it back into the USB cable.
Good Luck
SOURCE: Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
SOURCE: Kodak EasyShare C653 Camera, cannot connect to my macbook
Try a dig. USB plug,
Try a dif. cable.
Try with a cardreader.
If your cable is faulty it is covered under the same 1 year warranty as the cam.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: it wont download pictures to the computer
If I remember correctly, you needed to install the software and the drivers before connecting the camera by USB cable. It should all have been done with the camera not connected.
If you did it while it was connected, you must try uninstaling the software, and going into Device Manager and finding the specific driver fot that camera and Kodak, and removing that too.
Then restart your PC and start fresh.
Do the Software and Driver installation without the camera being installed or attached.
Once you have done the installation of software and driver, then, following the instructions, you can attach the camera and it should work this time.
