Everytime I turn my washing machine on it comes up with E2 on it
Old code E2 New code 5E.
FAQs My washing machine is displaying an error code What does it mean...
SOURCE: Haier HWM5TL E2
I looked at the Haier website and all other usual sources but could find nothing. I think you should e-mail [email protected] with the same query. Good luck
SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
SOURCE: Hello. We have a Mezzo
hi i just had the same problam the washer wasent pumping so i took out the pump the washers inside the pump were falty get a new pump and it will work again the problam is that the seals ware out and fill the pump motor with water hope this helps
