Error code E13 stopped washing in middle of cycle
The "E13" error code on the WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" ) What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely. You haven`t mentioned if you`ve checked the pump...just hoses as you did mention. Anyway, here`s the most likely way to remedy a E13 code. **Unplug the washer from the wall or turn off the breaker before attempting any repairs** Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain ) Locate the round door on the front of the machine (about 6" in diameter, lower right corner) Find a drill bit or small screwdriver that fits in the hole in the round door. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves). Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks. Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first. Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly.
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
I'm fairly sure that this is a warning that the filter is blocked. There is a filter in the bottom right hand corner of the machine.
Now, as stated by the other user here, your problem is that you have a machine full of water and if you remove the filter, you are going to get a very wet floor. The trick here is:
Turn the power off at the mains and remove the plug from the wall. Wait ten minutes. This SHOULD power off the safety feature that allows you to open the front load door.
Presuming it does, pull the machine out if it is under a work surface and taking great care because of the weight, tip tha machine backwards until the water level is below the door (Having a chair or a box to rest the back of the machine on is a good plan here, so you don't tip it beyond about 45% and have it fall on ots back.
If the door will open, then you can now rescue any clothes and bale out the water with a cup. Once you gave got to all the water you can (Memember there is still more waqter out of sight and in the pipe going to the filter!) You can now tip the machine back a little further until the water is clear of the filter in the botton right of the machine.
NOW, you can take the filter out, remove the fliff, couns, old sock and other debris clogging it and screw it back in place. TIp the machine back on to its feet and put it back.
Now, make a note in your diary to check the filter ever 6-8 weeks or so. Once you have done a few check and cleans, you will figure out how oftem you need to clean the filter, which depends on what you wash and how much you wash it.
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
SOURCE: I'm finding my electrolux inspire
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: Electrolux Eco Valve EWF1087 washing machine,will
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
