When i power on the tv a blue message box says "no video signal". How do i resolve this issue? I can not get a picture. I hooked up my coaxial cable wire from the cable box to the tv, powered it on and get this message
SOURCE: Dell W3201C: No picture, No sound
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
SOURCE: Screen Blackout
Don't bother with DELL if out of warranty, they can't fix it.
SOURCE: Dell TV no Sound
Replace the Philips TDA8925ST "Class D" amplifier chip, readily available from Rich-Tech in Richmond, B.C. Canada.
SOURCE: 42" Dell plasma TV
Y SUS and Buffers are usual culprit.
You can get it from guy at
[email protected]
He has everything for Dell TVs
SOURCE: What is the factory reset code for the dell w3201c
Code is 3355
If that fails, try this
* Press and hold the Input Source button - on the TV (not on the remote); continue to hold it until the last step
* Press and release the Power button
* The TV turns off
* The TV turns on
* Wait 10 seconds
* A message appears saying the TV has been reset
* Release the Input Source button
