Please be very clear on this because I am new to sewing machines
SOURCE: Settings
Width is one.
Length depends on the thickness of the fabric; 2.5 is the normal setting, but you may have to adjust to your liking or the age and condition of the machine you are using.
Fold a scrap of the fabric you will be sewing and test the settings, then write the settings down or on the sample for future reference.
SOURCE: I can not figure out
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
SOURCE: how to set straight stitch
You can buy a manual for the Simplicity Fashion Pro SW2145 from this link
http://www.sewingandcraftclub.com/index.cfm?fuseaction=product.display&Product_ID=3112&category_id=365&picksku=IBSW2145#top
I would guess from looking at an image of the machine, that you just turn the large dial on the front around to the number for the stitch you want, based on the selection displayed across the front of the machine, blue and red stitches. You may need to switch between blue and red on the selector to get the 2nd range of stitches, probably stretch type where the machine goes forwards and backwards ones, I'd guess.
And vary the stitch width using the dial beside the reversing lever on the lower front.
SOURCE: Stiches are not sewing straight - will go straight for several stitches & then
it says go straight fo rseveral stitches & then? need more information
