Question about Franklin Industries Franklin Chef FIM200 Ice Machine
How do I hook up the solenoid water valve on my Franklin Chef ice maker model FIM200?
I have a model FIM200 that is missing the solenoid valve. How do I hook up the new one.
  • 2,119 Answers
Posted on Sep 11, 2014
3 Suggested Answers
6ya staff
SOURCE:
carldc3
carl carpenter
  • 82 Answers
SOURCE: where can I foind technical
what part are you wanting, water inlet is usually 3/8 npt, this unit can use 1/4 to 3/8 inch line
Posted on Jan 23, 2009
edda3rd
  • 3 Answers
SOURCE: My franklin chef FIM200 is
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
Posted on Feb 01, 2011
Not water in the door
For a 1993 model, the problem is most likely a clogged inlet strainer on the solenoid operated valve on the back side of the access cardboard cover near the bottom of your refrigerator. If you take your model number to Searspartsdirect.com and you can order a new valve if the solenoid has finally stopped working.
Before to much troubleshooting, check the isolation valve where the water hose hooks up is open. It may be someone closed the isolation valve.
Hope this helps
Dec 15, 2014 | Refrigerators
Just hooked up (water lines only, no control wiring yet) a 3 station Jar top Manifold. One of the valves is open while the other two are shut. Have taken apart and see not apparent reason for it to be...
Make sure the bleeder is closed or solenoid is tight. Sometimes valves just fail without a obvious reason. Suggest purchasing the same jar top valve and rebuilt it using the new diaphragm, spring, bonnet and solenoid. This should correct the problem.
Apr 13, 2014 | orbit"" 1"" jar top valve"
99 ford expedition level ride won't let air to rear air bags past solenoid mounted mid frame.
The better scanners can hook up to a connector port and diagnose the air lift system. This saves diagnostic time and the expense of replacing good parts. The trigger for your air ride system is probably one that you would not imagine. The trunk lid switches and the door jam switches tell the car that it needs to lower or pump up the system. The idea is that you want the car lower to load passengers and to lift things into and out of the trunk.
When these trigger signals reach the solenoids it is their job to add or release air. At least your pump is working. The diagnostic scanner will tell whether the solenoid is bad or a signal is missing to the solenoids. There is a master dump valve in front of the drivers wheel well to lower all ends at once.
Aug 27, 2017 | 1999 Ford Expedition
On my 2000 Golf 1.9 tdi ALL vacuum hoses are disconnected. How do i connect the hoses between the turo boost control valve and the egr solenoid valve as well as the main vacuum hose from the vacuum pump. I...
You will need a Vacuum hose diagram to hook thes up correctly. There should be a diagram on the hood or raiator cover of the vehicle. If the diagram is missing you will have to take ALL info from your car (Year,Make, Model, Engine size, Engine code) and obtain the diagram from a dealer.
Jul 28, 2011 | Volkswagen Golf Cars & Trucks
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
My franklin chef FIM200 is dripping water from the back, right side. The water fill valve was spraying out above the tray, we managed to get that under control, but, water is dripping right behind that...
Nov 24, 2010 | Franklin Industries Franklin Chef FIM200...
I have a Nissan Titan 2006 and when we hooked it up on the diagnostic computer it shoed an EVAP code. We did the smoke test but nothing was showing for a leak. What do I need to do. I checked my fuelcap...
Did you remove the shrader valve from the purge solenoid, and put on adapter for smoke. It has to be closed, otherwise
Did you not component check,according to the Evap Code
Where all system valves closed or hoses removed and plugged. Missed something
Sep 30, 2010 | 2006 Nissan Titan
Location of wires to hook up the solenoid valve
Down by where the valve is screwed onto the fridge , there will be 2 wires usually coverer with masking tape . Sometimes , the 2 wires are in a plug ,which plugs onto the valve .
Aug 06, 2009 | Refrigerators
Franklin Industries Franklin Chef FIM200 Ice Machine Logo
193 people viewed this question
Top Franklin Industries Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
