We have installed a Lowboy L56 50 DOLS 1026T449635. The breaker is new and is a 30 amp. The wire is 10 gauge. The wires aren't crossed and each shows 120 volts when tested. The panel shows 120 on each...
Question: Do Low boy heaters, have a heater at the bottom, AND at the top?--- and are BOTH of the heaters working, on the 'either/or thermostat?
(By 'either/or'-- I mean, that it first turns the top element on, and when it is satisfied, THEN it turns the bottom on, until the whole tank is heated..) -- I would say this is an advantage of the taller tanks...
The taller tanks stratify VERY WELL--- (And the incoming cold water stays right at the bottom, and you take the HOT water off the top-- until suddnely it all goes to COLD.
I am wondering if the Low boy heaters might MIX more thatn the tall ones,-- thus going to WARM water sooner--- due to poor stratification.
Could you test that out, and try to folow the cold water line up the tank, as the Hot water is drawn off?
Another thought:
The Cold Fill tube, does go all the way DOWN to the bottom of the tank, right?--
And does it gently let the cold water flow across the bottom, and not 'rotatee the waer in the tank, as it replaces the hot water being used?
Otherwise the cold water will mix very early-- and give this same problem...
(I have heard of those center tubes falling off in shipment...
Did you by any chance check that, when you installed it?)
A final thought: What if the water draw was extremely fast?-- (Like if the water pressure is exceptionally HIGH--) might that upset the stratification, and cause the same problem, too?
If the hot water is drawn more slowly, can the customer get 30 or 4 gallons of HOT water, before it all goes cold?
Mack B
