SOURCE: kirby heritage 2 sweeper
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
SOURCE: Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
SOURCE: i,m down to the removal
Ok so Once i took off the back/engine cover (lift the plastic near the switch theres another screww there) go the front and take out the 2 screwws that hold the hose attachment switch.
I you hold the fan and insert a strong bar/small screwwdriver in the hole on the splindle (dont use your needlenose pliers like i did cos they break!) turn er anticlockwise i think and it all comes loose easy enough
And thats pretty much it replace the fan and reverse your action to finish the job
thanx to those who wrote their answers
SOURCE: replace my fan on my kerby
I had to replace mine fan yesterday. I broke away some of the outer pieces and grabbed the fan around the center with some vise grips and put another vise grip on the shaft. ( You can also put a hard steel tool of some kind through the hole in the shaft) when facing the front from the attachment side the shaft unscrews when turning it clockwise.It comes apart right in front of the fan where the washer is.
SOURCE: looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
