SOURCE: LCD is not working
Hello, in order to repair this Camcorder you should replace the LCD panel flexible cable FP-185 and the plastic hinge cover. If you need more info please advice. Best regards. Arpi
SOURCE: No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
SOURCE: sony CamCorder Model DCR-HC42E . (lcd showing blank)
i have the same proble , pls any sugestions?
SOURCE: DCR-HC19E Camcorder LCD Screen not Working
DCR-HC19E has cracked/ broken flexible cable, connecting LCD and main camera board.
SOURCE: LCD screen not working on my Sony Hc 42 camcorder
Hi
The LCD cable is faulty. You need to replace the LCD cable from SONY authorised service center.
It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.
If
the touch screen of the Camcorder is not working, please follow the
troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check if
that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please
remove the battery pack, turn the Power switch to ON for more than 15 seconds,
turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
I hope this information will help you to resolve the touch screen issue of the
Camcorder.
