That's a great question, friend!
I see you question is labeled under model FGES3065KB. In order to remove the drawer on that specific Frigidaire range you would need to follow these steps:
1. Open the drawer to full position.
2. Locate the latches on both sides of the drawer.
3. Pull up on the left glide latch and push down on the right glide latch.
4. Pull the drawer away from your range.
I hope this information is helpful to you. -Matt
Hello friend, thank you for your post!
From my understanding you have some questions regarding the operation of your Frigidaire microwave. The fan will turn on when the temperature sensor recognizes the temperature is too hot. There should be suction from the bottom. If you are experiencing issues with your new microwave I would recommend contacting your manufacturer for proper warranty coverage. I hope this information is helpful to you. -Matt
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Good Afternoon Friend, this is Z. I am happy to assist you! I see you are looking for instructions on how to remove the bottom drawer of your Frigidaire Gallery electric range. May I have your model number please? The serial tag, which provides your model number, is usually located in the storage drawer, on the right side. With this information I can provide the correct information to you. Thank you!
FGGF3035RFA
