Kenmore Elite Microwave, Model 721.66339011, Open Box tbc827 Logo
A
Anonymous Posted on Sep 09, 2014
<!-- from fixya rte -->How Many cubic feet in a elite? - Kenmore Elite Microwave, Model 721.66339011, Open Box tbc827
mbarre
Level 3:
  • Master 937 Answers
  • Posted on Sep 10, 2014
mbarre
Master
Level 3:
Answers
937
Questions
Helped
311210
Points
5626
This is a 2.0 cu ft model. link to user manual:
http://kitchen.manualsonline.com/manuals/mfg/kenmore/721_7920.html?p=1
What is cubic feet is MW1030WA microwave oven
1.1 cubic feet.
You can find the cubic footage of a microwave by measuring (in feet) the length x width x height of the inside of the cooking cavity.
If you have other questions, please feel free to contact me directly (see below). . - William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
What is the cubic feet
cubic feet is the measure of volume. one cubic foot is 1x1x1 foot. the size of the microwave varies with MAKE and MODEL. but is normally in the range of 1 to 3 cubic feet
2answers
15x14x9=how many cubic feet?
Square feet is calculated L x W so 10x10 would be 100 sq. feet, Cubic feet is calculated by L x W x H so 15 x 14 x 9 = 1890 cubic feet
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
Inches to cubic feet
The cooler is about 5.08 cubic feet. it may or may not fit depending on the shape of the trunk.
About 9.17 cubic feet.
Convert cubic inches to cubic feet
Since there are 12 inches in a foot, there are 12x12x12 or 1728 cubic inches in a cubic foot.
Dividing 1404.4921 by 1728 gives about 0.8128 cubic feet.
What is cubic square feet
Cubic square feet is determined by multiplying length (depth) X width
X height. Example= 2X2X2 = 8 cubic feet. A typical countertop microwave is going to be 1.1 to 1.6 cubic feet of oven capacity.
1helpful
We have the GE JVM130H 001 microwave. I am trying to figure out what is the cubic feet capacity of this microwave. Can anyone tell me?
Hi, W/D here.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet.
For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft.
Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
