The lower part inside the seat back is a rubber loop. Just push the rubber loop off the stud and pull the button out. These are so easy to remove. Junk yard might just give them to you (if not, they are probably only $1).
find bolts under the front of the seat itself. remove this seat and you will see 2 more bolts at the base of the back of seat part. remove these and normally the back part lift off some retaining clips. Replace in reverse order
Air filter changement for 2002 VW Jetta 1.9 TDI: 1. Unplug MAF Connector. 2. Unscrew two Air Filter Housing screws - Phillips driver. 3. Screws do not come out fully. They remain loose in the Housing. 4. Remove Air Filter Housing. Lift up/towards. Rest on battery cover. 5. Remove old Air Filter. 6. Clean Filter Housing. Damp cloth. 7. Check upper half of cover too. 8. Insert new Air Filter. Ensure the edges are seated. 9. Reposition Filter Housing. Clips on leading edge down/in first. 10. Two screws (don't overtighten). 11. Reconnect MAF plug.
slide the seat right forward and undo the two bolts in the slider then slide right back and undo the front twothen lift it out.when you put it back make sure the bolts are tight....
water ingress in wiring loom below drivers seat, mainly loss of power to pin 23 middle multi plug blue and red wire middle multi plug.
remove drivers seat/frame trace wire back to corroded connection and repair. you may also have to remove passenger seat depending on where the break is. dealer quotes upto 2 hrs
You'll need to move the front seats up and there is a screw at the bottom on each side of the console that needs to be removed, also I believe there are a couple other screws to remove.
