Water Heaters Logo
A
Anonymous Posted on Sep 09, 2014
Where can I buy a pilot assembly for an American Standard water heater? I'm in Torrance, CA
Model # = G-50T1-3-6
Gene Haynes
Level 3:
  • American Sta... Master 5,391 Answers
  • Posted on Sep 10, 2014
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2603871
Points
14124
Contact AO Smith ?
http://waterheatertimer.org/Water-heater-manufacturers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5 Related Answers
Anonymous
  • Posted on Apr 10, 2009
SOURCE: gas water heater kenmore model pilot will not stay lite
I have the same problem. Water heater operates on a very simple principle. of thermo-mechanical feed-back and response. In my case, I have a Kenmore Power Miser 6, NG heater with an electronic pilot ignition system. The heater is just over one year old and last month (conveniently just after the 12 month service warranty expired) the pilot light started extinguishing on a very regular basis. I find it interesting that the very problem I am experiencing, is happening to other Kenmore owners (victims). The solution can be found in replacing one of two possible components; the pilot assembly or the gas valve manifold. The price of DIY pilot assembly replacement is approx. $60 . The valve component is significantly higher. Water heaters are designed and built to provide years of trouble-free reliable service. This is the first Kenmore product I have owned. From a customer perspective, with regard to product performance, Sears/Kenmore needs to take a strong look at their supplier quality. Oh, by the way, contacting Sears for remedial relief only managed to frustrate and infuriate me. You see, I am in Quality for a world-class aircraft company. I understand what ethical steps are required to satisfy a valued customer. I plan on ripping out the defective unit this weekend and replacing it with a reliable Home depot special. At least with HD, if the heater fails to perform , I can return it. Hey Sears in Chicago, don't come crying to the consumer when you are looking for the trendy "bail out". Signed- "Burned Out" in La Habra, California.
Anonymous
  • 582 Answers
  • Posted on Aug 11, 2009
SOURCE: My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Testimonial: "Thank you for the clear/thorough advice. Not only did you clarify the problem, but your suggestions on how to fix it were very useful too. "
Anonymous
  • 101 Answers
  • Posted on Sep 10, 2009
SOURCE: AO Smith water heater about 4 years old pilot went
It sounds like your flame detector (usually a thermocouple) has gotten weak and when you cleaned the pilot the stronger flame was able to generate enough power to keep the gas valve working. If you replace the thermocouple your problem should go away. If a new thermocouple will not keep the gas valve operating...the coil in the gas valve has gone bad and you will need to replace the gas valve assembly. (most valves do not have replaceable coils).
Anonymous
  • 1187 Answers
  • Posted on Oct 13, 2009
SOURCE: Atwood water heater - pilot light and flame malfunction
Michael,
The thermocouple sensor may not be in the best position to sense that the pilot is lit.
Adjust the thermocouple mount or simply bend the thermocouple "wire" so that the pilot flame is touching the tip.
Anonymous
  • 122 Answers
  • Posted on Aug 10, 2010
SOURCE: Will not light pilot light. Why?
did you bleed the gas line?
you must loosen the connection at the water heater until you smell gas coming out, then tighten. wait at least 5 minutes before attempting to light. this will give time for the gas to dissipate
if it still wont light... are the connections to the thermocouple tight? if that is tight, might be a bad thermocouple, you will need to replace it.
3answers
AO Smith 2012 water heater model GCV 40 300 pilot lights but then goes out. Won't stay lit
You only need the thermocouple replacing. It is the safety valve that won't let the main burner light unless the pilot is fully lit. As it is gas, you should have a gas certified technician replace it.
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Flame does not ignite
if you have a pilot light but no flame you need a thermo coupler very easy to change but you need
to turn the gas off and pull the gun out at the end of the gun the pilot light heats the thermo coupler
that tells the gun it has a flame at the end and its ok to turn on the gas for a flame home depot will
carry a new one for you
hope this helps you
good luck
bob
We are a small school that has about 14 students taking a shower after PE. We have had a 100 gallon 270,000 BTU water heater. Do you have a price quote for that heater American Standard Commercial Model...
Hi Kathlene.
Typical American Standard sell sheet for 100 270 AS also shows contact information for company with phone numbers
http://www.waterheating.com/pdf/100270.pdf
One seller shows this product for $3000 + shipping
http://shop.waterheatermaninc.com/product.sc?categoryId=2&productId=10
Rheem builds commercial gas water heaters under their name and under other brand names.
http://www.rheem.com/product.aspx?id=FC6D548B-54EC-46C9-9DC0-79DEC29198D7
Contact Rheem:
http://www.rheem.com/Contact.aspx
For example Rheem GP100-250(A) meets same delivery as American standard product
http://globalimageserver.com/fetchDocument.aspx?id=d26ba16f-c16f-4c45-90a8-d1f5d5f97020
One company sells product for $3900
http://bostonheatingsupply.com/ventmaster.aspx
For example model GD100-250(A) meets same delivery as American standard product
http://globalimageserver.com/fetchDocument.aspx?id=276b892c-1fb8-40f1-8238-51d4a7d84846
This product might sell for $6900
HEATER WARMS UP AND THEN GOES OUT.THEN IT HAS TO BE RELIT TWO OR THREE TIMES A DAY
Relighting the pilot of any water heater is a pain. The first thing to do is call the water heaters manufacturer for information on your specific make and model. If your water heater is under warranty, they will provide technical advice and free parts.
1. Replace the water heater's thermocouple. Make sure the pilot flame is centered on the shiny end of the thermocouple; it requires a certain amount of heat to produce enough electricity to open the main gas control valve.
2. Replace the main gas valve control.
3. Replace the water heater; I know this not what anyone wants hear.
1helpful
Pilot will not light
Unable to light pilot Gas supply turned off Turn on gas supply Gas **** knob dial not positioned correctly Check lighting instructions. Set control knob Defective thermocouple Check and replace thermocouple Defective safety magnet assembly Check and replace gas valve Pilot burner orifice clogged Clean or replace Pilot tube pinched or clogged Clean, repair or replace Poor thermocouple connection Check and tighten Air in gas line Purge air from gas line Thermostat's single use ECO is tripped Check ECO and replace gas valve Gas valve defective Check gas valve
Top American Standard Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an American Standard Water Heater Expert? Answer questions, earn points and help others
