Need to disassemble a Toshiba Satellite c55-b5299 in order to increase the Ram. The laptop only comes with 2GB of Ram. I would like to have at least 4GB and preferably 8GB
SOURCE: adding RAM
no there is not a order for that but you can try one by one like that you'll see if that is detected or not so if any one is not detected or does what it was on the first time may be there is a bad one so try it
SOURCE: EXTENDING EXIST 2Gb RAM to 4Gb
hai ,frist u go to
start--my computer(right click it)---manage---disk management---
see your new hard disk & right click and shirnk volume
SOURCE: can get computer to turn on after installing 2GB
possible the chips arent seated properly or they may be the wrong type
SOURCE: Repair DC Jack in a Toshiba Satellite P15-S420 Laptop
Follow the link below, it is an illustrated guide to the disassembly of the P15. Pages can be changed at the bottom of each page shown. Just copy and paste the link into your web browser's address bar.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p15/removing-motherboard-1.htm
Unfortunately, the slots on this motherboard are limited to a max of 2 GB each. You won't be able to use a 4 GB DDR2 800MHz memory stick with this computer. (This limit is due to the way the circuitry/programming of the board was designed.)
I wish that I had better news for you. You might be better off installing a Unix based OS which uses less memory or searching for a new laptop. Just remember to save your files on a different drive before making any changes.
