Clothes are very wet/damp after the spin cycle completes. Drum spins, washer is level and drain is not restricted. Water appears to drain out, but not sufficient spin speed or sunction to extract the water. Thanks.
yes, most of the time all the water is still in the machine after the spin cycle.
WHILE SPINING THE WASHER SOUNDS LIKE IT IS KNOCKING
detergent is clumping, occasional water leaking on floor when washer is jumping around..loads are getting unbalanced way to often...and i noticed that it is agitating in one direction only....isn't it supposed to agitate back and forth?? i think that is causing the load to be unbalanced?? i have no clue where to start to fix....
the washer completely stops working after filling, usually starts working again if i just leave it alone and pray- seems like maybe there is some sort of sensor and it is overloaded even though this is a "super capacity". have to use on mini cycle otherwise the clothes are still dripping after spin cycle. i have had no luck with this washer and am completely backed up after it being out of commish for one day
clothes are still wet after spin cycle
