It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
Not sure what you mean by rings over the intercom. Do multiple phones have the lines on them and they all ring or do you put it on night service for the other phones to ring.
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
My Dear Please First check the Phone settings in the Ringing Setting IF Your Phone Ringing settings all Ok But Phone in the not Ringing So
Your Phone Ringer Default So Please change Ringer and Ringing Problem will Solved
This is set on the buttons for the phone from within the system programming. Individual buttons can be set to NO Ring, Ring, Ring Continuous, Delay Ring, or Delay Ring Continuous.
Continuous meaning that even if you are on the phone, it will ring audibly on your phone. If it's not set to continuous, it will only give a blip.
You should contact your vendor for assistance in setting this up.
2.) What if someone dials you on intercom does it ring then?
If #1 the phone SYSTEM usually has an option that you have to program and add you to the ring pool for the outside lines.
If #2 does not ring it is also a function to disallow ring, but it very well could be the phone. Since the line is all that matters and NOT the phone, you could try another phone at your location and see if the same happens. If it does, you will need to program the SYSTEM from either Ext. 10 or 11 to add you to the ring pool and allow ring.
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
is the ringging assignment setting means downstair phone been set for incoming ring, so u can see the indicator ligh on and ringging up stair dint assign a incoming ring so that u only can see the indicator light always blinking w/o ring... contact yr phone provider to set the ringging assignment
is because the ringging assignment only set to ring at receptionist phone. u may need contact the phone provider to set the ringging assignment to other for other phone which to ring for incoming call
