send it back, flashing light is a power supply board problem, comes to light in all models except most recent z2 models.
return and it should be fixed by compamy foc .
red light flashing indicates power supply falure which is a common problem, retrun to point of sale or contanct b and w service. they normally fix it foc.
well you could notify b and w with the problem and they will charge you, however your unit will probably have the problem power supply board, so if you report that the red light flashes and the unit does not play, they will put the modified board in and fix your arm at the same time.
the red light flash relates to a fault on the power supply board, until they fix that, which is a known problem, it will not work, contact your retailer or b and w service if you have not already done so.
the rumbling would relate to component failure, and when the red light flashes the power board failure has kicked in, these are known problems with current models in all but the very latest, there are twoboards which tend to be replaces, so just contact retailer or b and w and they should fix it with no bother.
