Ericsson T202g Gpon Sbu Voice, Data, And E1 Internet Broadband Switch Eda1500 Logo
e
emmalee Posted on Sep 09, 2014
What is the typical configuration of MA5600?
What is the typical configuration of Huawei DSLAM MA5600?
candytang
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Sep 09, 2014
candytang
Contributor
Level 1:
New Friend:
Answers
21
Questions
21
Helped
3838
Points
55
Http://www.huanetwork.com/huawei-ma5600-price_p3862.html typical configuration: you may follow below steps:
1, Choose the main control board SCUB quantity, one or two;
2, Choose the uplink pinch board, O4GS(4GE Optical), O2GS(2GE Optical) and E4GFA (4 GE/FE Electrical) are commonly used;
3, Calculate how many ADSL2+ or VDSL2 subscribers to be connected, Huanetwork most stock are 64-port ADSL2+ over POTS(with 600ohm Splitter) board ADEE;
4, Choose the subscriber cable length;
5, Choose accessory, SFP module, patch cord.
About the typical configuration of MA5600 You may follow below steps:
1.Choose the main control board SCUB quantity, one or two;
2.Choose the uplink pinch board, O4GS(4GE Optical), O2GS(2GE Optical) and E4GFA (4 GE/FE Electrical) are commonly used;
3.Calculate how many ADSL2+ or VDSL2 subscribers to be connected, our most stock are 64-port ADSL2+ over POTS(with 600ohm Splitter) board ADEE;
4.Choose the subscriber cable length;
5.Choose accessory, SFP module, patch cord;
What is the difference between Huawei H837ASPB H838ASPB H839ASPB?
Huawei H837ASPB has the same functions as H838ASPB; therefore, H837ASPB can substitute for H838ASPB.
Compared with Huawei H837ASPB/H838ASPB, H839ASPB supports a new function: direct current-isolated (DC-I) grounding.
More related:
Huawei MA5616
Huawei DSLAM,
Huawei ADPE
How to Change the Service VLAN to Which the xDSL Port Belongs
Changing the service VLAN to which an Huawei xDSL port belongs means changing the service port configuration, namely, the PVC configuration, of an xDSL port. To change the service VLAN, run the undo service-port command to delete the service ports (PVCs), and then configure a new VLAN for the Huawei xDSL port.
The prerequisites for deleting a service port are as follows:
When you specify parameters, all the matched service ports will be deleted.
A service port cannot be deleted in the following conditions:
The port is encapsulated as PPPoA, IPoA, or Auto.
The port contains the BTV user.
The port is bound with an IP address or a MAC address.
The port is configured with a static MAC address.
Huawei MA5600
Huawei MA5616
Huawei DSLAM
How to enable two xDSL ports of the MA5600 to communicate with each other?
Two xDSL ports of the Huawei MA5600 communicate with each other through service ports.
If the two Huawei xDSL ports are on different boards, establish a standard VLAN, create one service port for each Huawei xDSL port, and then add the created two service ports to the established standard VLAN.
NOTE:
The service ports can be added to the standard VLAN only when the attribute of the VLAN is QinQ.
If the two xDSL ports are on the same board, establish a super VLAN, create one service port for each Huawei xDSL port, and then add the created two service ports to the sub VLAN of the established super VLAN.
How to Prevent System Breakdown or Service Interruption of the MA5600 Caused by Network Attacks Through the Proper Configuration
The common improper configurations that affect the system security are as follows:
The ring network detection function and the anti-MAC address-spoofing function or anti-IP address-spoofing function are disabled. When the anti-MAC address-spoofing function or the anti-IP address-spoofing function is disabled, the ******* user sends the PPPoE and DHCP control packets by forging the MAC address or IP address of a legal user. In this case, the security of the system is affected.
Huawei MA5600
Run the ring check command to enable the ring network detection function on the user side
Run the security anti-macspoofing enable command to enable the anti-MAC address-spoofing function.
Run the security anti-ipspoofing enable command to enable the anti-IP address-spoofing function
The devices are managed by IP addresses of the public network and the access rights are not limited strictly when the ACL rule is configured. In this case, the network is attacked.
To ensure the security of devices, manage the devices by using the IP addresses of the private network. When configuring the ACL rule, you must comply with the principle of the minimum authorization to configure the accessible address segment. The accessible address segment can contain only the mandatory IP addresses of the management network segment. Other IP addresses cannot access the device management interface.
Run the acl command to create a basic ACL and enter the ACL mode. The number of a basic ACL can only be in the range of 2000-2999.
In the basic ACL mode, run the rule command to create a basic ACL rule. The parameters are as follows:
rule-id: Indicates the ACL rule ID. To create an ACL rule with a specified ID, use this parameter.
permit: Indicates the keyword for allowing the data packets that meet the related conditions to pass.
deny: Indicates the keyword for discarding the data packets that meet the related conditions.
time-range: Indicates the keyword of the time range during which the ACL rule is effective.
The packets that access the device management interface are not controlled so that the device is attacked by the packets. In this case, the system is caused to be busy and the services are affected.
Run the firewall packet-filter command to apply the packet filtering rules of the firewall to the interface to filter the packets that access the interface. In this case, the packet attack is prevented.
Huawei MA5616
Huawei MA5616 Gold Line
Huawei MA5616 Silver Line
What Are the Index Values of the MTTR and MTBF of the MA5600?
A: The networking environments are different and the device uses different boards. Therefore, the reference value of the MTBF of the Huawei MA5600 is 55 years and the reference value of the MTTR of the Field Replaceable Unit (FRU) is two hours. The preceding values are only for reference. For details, contact the related www.thunder-link.com
More suggestions:
Huawei MA5616
Huawei DSLAM
How to verify the success of UA5000 hairpin connection configuration
Handling Process
A:Run the command display esl online-info all to check the DSP resource occupation: huawei(config)#display esl online-info all ------------------------------------------------------------------------------ UserPort DSPPort Codec PT EC VAD Gain(I/O) Duration(hh:mm:ss) Urgent ------------------------------------------------------------------------------ ------------------------------------------------------------------------------The call does not occupy the DSP resources, which indicates that the configuration of hairpin connection service is successful.
Root Cause
1. For subscriber A and B in the same MG, the hairpin connection is to connect the timeslots of subscribers A and B on the network chip for the call between A and B. 2. The hairpin connection service does not occupy the DSP and bandwidth resources.
Suggestions
Alternatively, you may capture packets and check whether there are RTP streams sent to destinations beyond the MG. However, the above method is simpler.
Huawei DSLAM
Huawei MA5616
What is the difference between MA5600 and MA5603?
Basically they are with different capacity, MA5600 support 14 service slots, MA5603 only support 6 service slots. http://www.thunder-link.com/HUAWEI-MA5600_p599.html
2answers
Can I configure a MA5616 with 256 ADSL2+ ports?
Yes, but the 64 ADSL2+ ports board price is high, also have requirement on main control board which may make your cost high, so suggests for small site purchase the Huawei DSLAM with 128 ADSL2+, if need more than that consider big MA5616 MA5600 or 2 units MA5616 using cascading.
http://www.thunder-link.com/HUAWEI-DSLAM_c126.html
Top Ericsson Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ericsson Electrical Supply Expert? Answer questions, earn points and help others
