What is 59 co .error turn off turn on? pleas imidiatly answer
I presume you are referring to the HP Model CP1215. The error 59.C0 error appears to refer to a mechanical error: Developer motor rotation error.
The recommended action is 1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize. 2. If the problem continues, contact HP Customer Support Center for technical assistance.
Your printer could be about 5 years old by now, so if this is a recurring problem you might be nearing the time for a replacement which might be less costly than taking your printer to be serviced.
You
SOURCE: PCL XL error in hp laserjet 3055
information about the cause:
PCL XL error pages that print from an HP LaserJet 1200, 1300, 2200, 2300, 3200 or 3300 series product when a PCL 6 printer driver is in use typically indicate a communication issue. Sometimes this issue is caused by an incompatibility between the Enhanced XL language and the software application.
You can find the solution for this error here:
(It's a long instruction page, I advise to copy the sections that refere to your OS to a separate document, so you don't miss any step)
URL to HP service page:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1161389&prodTypeId=18972&prodSeriesId=1161389&objectID=bpl10637
SOURCE: error message replace drum for printer hp laserjet
pristonero, there is no "main" button. what are you talking about?
SOURCE: I want to know what the problem 59.CO message on
59.XY PRINTER ERROR
A printer motor error has occurred.
(C)= developing disengaging motor rotation error / (0)= no color/black
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
SOURCE: PCL XL error on HP color laserjet 3600n
Verify printer functionalityTo verify printer functionality, use the following steps:
Try to print a page using the software application or a document in question after attempting each item of the following workaround. This will help determine if the changes made have caused the desired results to occur.
If the error is not resolved, try a different IEEE 1284-compliant cable. If there is no possibility to direct connect, use a different network cable, or network port, on the hub. Simplify communication options depending on the specific printer. Use the Control Panel on the printer to turn off High Speed andAdvanced Functions . To turn off High Speed and Advanced Functions complete the following steps:
For problems with certain applications or documents, try modifying the HP LaserJet printer series PCL6 driver settings, such as:
Some more steps:
General troubleshooting tipsContinue to isolate the error by printing the job in question after applying each of the following suggestions:
