I hope the laptop still starts otherwise you will need an installation disk to recover/reset and check this link http://askbobrankin.com/3_ways_to_repair_windows_8.html
Reset? As in re-install the laptop? Difficult to say exactly if your computer has a recovery image. Try to press F8 repeatedly when you switch the laptop on, then choose repair my computer. You may see a recovery option alongside other things such as command prompt etc
SOURCE: fn key for laptop sony vaio vgn-s460p
the function keys doesnt need any extra driver.
but if you want to use tha additional features of function key like save, load, close and many more then you can get the software directly from official website of sony. alternativel you can download hotkeycontrol xp by which you can reconfigure you keyboard to add extra feature and options
SOURCE: I need to replace my sony vaio VGN-N series laptop
Here is some instructions:
www.yboyandrei.com/VGN-N
Please rate me.
Thank you.
SOURCE: VAIO VGN-Z520N/B 13.1" Laptop : where is the volume control on sony vaio laptop...
You can use the Fn+F3/F4 Function Keys to control the volume.
To increase the Volume, press Fn+F4 and then press Up or Right, or Keep pressig Fn+F4.
To decrease the volume, press Fn+F3 and then press Down or left, or Keep pressing Fn+F3.
Hope this helps..
SOURCE: VGN-SZ330P laptop stays on opening VAIO screen after two beeps
Just hold down the F1 key after the two beeps and the computer should continue to boot up as normal
SOURCE: sony vaio vgn-fs775p laptop real time clock not keeping time
Properly Configure Time Zone Make sure that you have properly
configured the time and selected the right time zone. Configuring the
time zone properly may fix clock that keeps resetting. To do so follow
these steps: Check CMOS Battery There is battery named CMOS
on the motherboard, if this battery becomes dead PC loses its date and
time settings. Problem in battery may result in this issue. Replacing
the battery with a new one is the best solution to fix the problem. Install Windows Update Some of the Windows updates
also contain a patch to fix clock keeps resetting. To download and
install latest Windows updates follow the steps below: Repair Windows Registry Mostly PC problems occur due
to corrupt Windows registry. To fix clock keeps resetting problem you
are required to fix registry error. You will need a good System
Utilities program that includes a Registry Cleaning feature. Registry
Cleaner deeply scans registry problems and fixes them instantly. To download System Utilities program including a Registry Cleaner click here. Scan System for Viruses Attack by viruses or spywares
on PC may also results in this problem. To fix this issue you have to
completely scan your system for malicious or infected applications and
clean all the files detected by antivirus program.
2-Click the "Help and Support."
3-Select the "Vaio Recovery Wizard" option.
