Panasonic Viera TH-42PZ80U Plasma TV Logo
William Martin Posted on Sep 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anyone know how to fix a Panasonic Viera 50" Plasma that powers off a couple seconds after powering on?
The display turns on and displays the screen like normal, but then shuts off after a few seconds. I can hear the fans running in the back, but everything shuts down and the power light (red) blinks. If I hold the power button down and release after a few seconds it will power on again, but only for a few seconds. Seems like there is a power overload or a short causing it to malfunction. Anyone have any ideas?
  • William Martin Sep 24, 2014
    Turned out to be the fans were so clogged with dust that a couple of them weren't able to spin freely. I removed the rear cover, vacuumed out all the dust and cleaned all 4 fans, now it powers on without a problem!
Col Dana Gillespie
Level 2:
Novelist:
  • Expert 167 Answers
  • Posted on Sep 09, 2014
Col Dana Gillespie
Expert
Level 2:
Novelist:
Answers
167
Questions
Helped
30739
Points
407
TThe diagnostic circuits is shutting your TV down. In most cases the set will shut it down immediately. Apparently your set hasn't shut completely down yet. When you turn your TV on the diagnostic circuits send a low voltage, low frequency signal through all the circuits and depending on how they come back whether the sets powers up to full power. If a problem is detected it will shut down to protect the other circuits. It sounds like you might have some capacitors going bad on your power board. A capacitor that is going bad would let it come on for a few seconds then the diagnostic circuits would see the capacitor getting further out of tolerance and shut the set down. If you are a DYS type person you might want to lay it flat of it;s face and remove the back. A bad capacitor will be bulged out on the top. are Replace capacitors with the exact uf value and if you can go above the rated voltage but never below., If this isn't the problem then it is probably the main board (the board where your cable hooks up to), There are other things that cab causes for this but I would check the capacitors first.
Col. Dana Gillespie
5 Related Answers
tiafau
  • Posted on Oct 07, 2007
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
djchillsnyc
charlie rodriguez
  • 152 Answers
  • Posted on Oct 14, 2009
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Anonymous
  • 458 Answers
  • Posted on Nov 10, 2009
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Steve LaHuis
  • 418 Answers
  • Posted on May 02, 2010
SOURCE: panasonic 42
Loss of power from power supply. Usually bad power supply.
Chi Chu
  • 8457 Answers
  • Posted on Jun 22, 2010
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Panasonic Plasma picture losing 50% of the screen!
it is likely the power supply board in the back of the tv. these are a huge problem. I fixed mine for $15 by taking it apart and taking the board to a repair shop. new cap on the board fixed it.
Panasonic VIERA TH-50PX25 DVD offset and blue color My DVD or VCR is offset on the screen ... ...
this Plasma TV working normally for 2 hrs & just stop &showing blackscreen display"chanel not available" I turn TV off & turn it back on again ,. now it have picture with no sound ...please help if any one know what is the problem is ...Thanks
5helpful
Panny TH-42PZ80U Plasma TV No display on Power-up
I had this same exact issue. Panasonic sent a repair tech to my house since I was still under warranty. The tech was able to fix me up in about 10 minutes. He replaced the "brain" or A-board and now I'm back in business. This is NOT a power supply issue. The brain is the circuit board that has all the inputs attached to it (component, hdmi, etc...).
hope this helps!
3helpful
Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
50PZ800U 50" Panasonic Plasma won't keep displaying the source
Seems like the HDMI section of the plasma is damaged. I would call Panasonic and try to get it serviced under waranty since the display is less then a year old. Just make sure you dont mention anything about a storm or power surge. Let them know only if they ask that you are using a surge protector/power conditioner on all your devices.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
