SOURCE: Alarm Malfunction.
remove the band and the back of the watch, rotate the back 180 degrees and replace. The alarm should sound again.
SOURCE: Help with battery problem on Timex Ironman Data
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
SOURCE: I canot figure out how
ALARM
Setting
Arming and Disarming the Alarm
When you are in ALARM mode (but not in setting mode) you may turn your alarm on or off by pressing & releasing the START/STOP button. A little symbol that looks like a clock will appear above the M in AM or PM when the alarm is armed. If it is disarmed, that symbol will not be there. If that symbol is showing when you are in regular time mode, then at least one of your 5 alarms is armed. You can go to alarm mode and use the RECALL button to scroll through all 5 alarms to see which ones are armed.
Good Luck
SOURCE: I need documention on setting the ironman watch
Hi twopi,
This is the direct link to all Timex watch instructions/manual:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope it helps.
Thank you for using FixYa.
SOURCE: how do you set a timex ironman wathc and how do
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
