Microwave Ovens Logo
A
Anonymous Posted on Sep 08, 2014
What to do when oven smells like burning plastic
We purchased the stove in 2012, but due to a delay on a remodel have just stared using it and every time we use the oven it smells like burning plastic and taints the food we are cooking
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Sep 12, 2014
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1015071
Points
6696
New ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 18, 2007
SOURCE: melted carousel in microwave / bad smell
For the smell, do a Google search for "smell microwave" or "odor microwave" for many great tips.
If you need a new turntable support, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
It's part # FROLPB017MRK0
Anonymous
  • 290 Answers
  • Posted on Feb 29, 2008
SOURCE: Plastic shield card is burning up!
It is my understanding that you can't get parts for a Welbilt Microwave anymore. The good news is that you can make one work from another m/w. Take your shield to a local appliance parts dealer and find a shield a little larger than yours. You should be able to cut it to fit your oven using the old one for a pattern. The rivets shouldn't be a problem as Whirlpool, GE, and Maytag all use similar plastic rivets to secure the shields.
Hope this helps.
Thanks, Mike
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 02, 2008
SOURCE: Maytag microwave OVER the stove
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • 111 Answers
  • Posted on Dec 20, 2008
SOURCE: GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 26, 2009
SOURCE: I have a JVM1630WB GE Spacemaker microvwave oven.
It's almost certainly a shorted high voltage rectifier diode or a failed magnetron.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Here are some handy links you or someone you know can use for test help:
(if it's not shorted or burned, it's probably okay)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If it's within the magnetron portion of the warranty (for this model it's 10 years from the date on the tag inside the unit) but out of the original full warranty (1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
G.E. they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Smell of Burning Plastic When Used. No Sign of Burning Outside
Panasonic microwave ovens do this just before the control board fails. May be time to replace the oven :(
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Goldstar microwave burning
Toss it, when the electronics burn up it isnt safe to use anymore. Or especially with microwaves cost effective.
1helpful
My Kenmore 721.626222 which I have had about 6 years, runs but does not heat. There is also a strange smell - something like a burning smell.
When the oven does not heat, the problem is usually due to the magnetron failing. It the part that generates the microwaves that heat the food. It fails by shorting out causing a loud buzzing noise. The burning smell is the being magnetron overloaded due to the short. It not worth fixing since the replacement cost of a magnetron is close to the price of a new oven. Sorry.
We brought a Tesco microwave at CULLOMPTON Tesco, Devon last week. It cost £29.00 on its first major use - cooking potatoes for ten minutes - smoke seems to be coming from beneath the machine - it has...
This is almost certainly some of the protective oils and varnishes which were applied during manufacture flashing off.
All new products of this type do this to some degree but your description seems to indicate that it's much worse than normal with your machine.
Ordinarily, you can expect this to cease after a few uses and if the level of smoke and odour you've described is to be expected then the instruction booklet should say so. But as yours has visible smoke and a burning plastic smell I'd recommend that you exercise your rights under the Sale of Goods Act and return it to Tesco for a full refund or replacement. The smell of burnt lubricant is one thing, but a burning plastic smell means you can never trust the oven to be safe: none of the many microwave ovens which I've dealt with have ever smelled of burning plastic unless there was a fault.
You won't find any objection from Tesco as they do have good customer service; and when I lived in Cullompton briefly earlier this year the local branch was even better than usual at keeping customers happy.
I hope that you have found my reply to be of assistance and ask in return only that you return the favour by rating my answer.
7helpful
3answers
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
GE Microwave Problem
Can you explain, in more detail, how it "Shut Down"? How did you "Restart"? Just be pressing START? Can you describe the "Crackeling Sound"? Does it still heat? Was there any Burning Smell?
Good News is: Your Magnetron is still in the Warranty Period.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
