SOURCE: Copy problems
1-if you make a copy on the glass instead of the feeder is it still there?
If no, then clean small 1" glass on copier there is a spot on it. even a pencil or pen dot WILL make a line on all copies. easiest way to find it, line up the paper on the small strip of glass and follow there will be something there ( sometimes it's hard to see since the background is black)
2- the drum has a black toner ring around it replace the drum blade or drum unit
SOURCE: Copystar cs-c2520 i have a faded line down the
Either a problem with the document feeder or something on the glass. If it's faded it may just be a roller not pushing the paper onto the scanning area properly.
SOURCE: After replacing the toner, it will only print on
Only prints the 3/4 of the top, the bottom or the sides?
Remove the cartridge. Be sure the seal was completely removed, shake the cartridge to the sides (like a wave movement) and put it back to the printer. It should fix the problem.
Check the installations instructions for the cartridge at the copier door.
