How to fix cartridge error.
SOURCE: hp officejet 4315 all-in-one
Please clean the copper contacts of the cartridges with dry cloth and then check the expiry date and ink level present in the cartridges.
If the cartridges are expired or out of ink, replace the cartridges and check for the result.
If the cartridges are not expired and not out of ink then insert the cartridges and check for the results, if the issue persists recycle the printer and then reset the printer.
SOURCE: cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
SOURCE: HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
SOURCE: My HP Officejet 4315 states Cartridge Error. Can
HP F2480
Align Cartridge:
If you have just installed a new cartridge it is recommended that you align it. Click on "Align" to align your new cartridge
SOURCE: I changed the printer cartridges in a hp officejet
Good Day Sir, hope this will help you.
print cartridge troubleshooting for hp officejet 4315 :
1. Remove the black print cartridge from the slot on the right. Do not touch the ink nozzles or the copper-colored contacts. check for possible damage to the copper-colored contacts or ink nozzles.
2. Reinsert the print cartridge by sliding it forward into the slot. Then push the print cartridge forward until it clicks into the socket.
3. Repeat steps 1 and 2 for the tri-color print cartridge on the left side.
4. If the problem persists, print a self-test report to determine if there is a problem with the print cartridges.
5. If the self test report shows a problem, clean the print cartridges.
6. If the problem persists, clean the copper-colored contacts of the print cartridges.
7. If you are still experiencing problems with printing, determine which print cartridge is experiencing the problem and replace it.
have a nice day.
7.
