Need to know how to print out meter reading.
I share a supported link please visit and read it points by points i hope solved your issues.
Read More... http://www.eid.toshiba.com.au/customers/c_eS4540c_Documentation/pdf/Printing%20Guide.pdf
If any more help.. Toshiba Printer Support
Thanks,
SOURCE: How do you meter read Toshiba e-studio 453 copier?
"User functions"
"print total counter"
That's it......
SOURCE: how to take the meter
you have to press the job status bottom and then press status, and show it
SOURCE: I need to know how
Hello mhitt,
Even though you have a pretty new copier, the ability to print the meter reading is not available. I know it's crazy since other copiers have been able to do it for years. Only the most recent models of Canon copiers have this ability. To print the meter readings for your copier would require that you go into SERVICE MODE and print a report that has several pages of **** and if you know what you are looking for you can find it.You could use the REMOTE USER INTERFACE (RUI) and view the meter and do a "screen print". I know it's not a happy answer but its correct. I wish you well. :-) By the way, the main meter reading (designated 101) is the count of sheets of paper that have successfully exited the copier regardless of size. My company uses meter "102" which counts 11x17 as 2 clicks on the meter. You probably cannot see this meter unless a service tech programmed it in.
