I'm having the same issue on all my Idevices. Once slotomania was updated from the AppStore you can't login to Facebook with the app. Facebook shows a blank widow and won't allow the login, and the app no longer loads :(. Guess its a Facebook issue. Time to pull out the old laptop and play that way.
SOURCE: Problem with running My Horse game on Galaxy Note 10.1 GT N8000
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
I have the same problem. Did a factory reset desperate to get Tabeo connected and lost all preloaded apps. I just got off the phone with a lady that helped me register the tabeo so that I can connect to the internet finally however, she was unable to help me get preloaded apps back. We have to call tech support 888-477-0888, their line has been busy all day but we just keep trying
SOURCE: I have a proscan PLT7223g tablet and trying to
You can avoid these errors if you have a stable internet connection. If the internet disconnects in the middle of the download then the error might occur. You can also try going to settings, applications and locate the google play store and tap it . On the play store tap clear cache. One of the reasons that the error occurs is if the download manager was moved to the sd card. Make sure also to check that. You can unmount the SD card and try.
