Already bought a brand new Polaroid Pogo printer but battery is dead. Where can I find one, as any market I see is out of stock? Or how I can make the printer work without the battery?
If you a reasonably handy you could disassemble the battery pack and replace the cells with new NiCad or NiMH units. They are not complicated and you should find lots of sites on the net that will supply the cells. Alternatively if the unit has a DC socket you should find the voltage and current printed beside it. Try fitting a suitable power pack.
SOURCE: Use of polaroid PoGo Zink printer with PC
The PoGo can connect to a PC with Bluetooth only. Once you establish a Bluetooth connection with your PC, simply copy any JPEG file to the PoGo using Explorer. No printer driver is needed, just copy the file to the PoGo over the Bluetooth connection.
If your PC doesn't have Bluetooth, you can buy a USB Bluetooth dongle for $5-$20.
SOURCE: got polaroid pogo printer will connect with
have you put the paper in with the barcode card piece at the bottom and did this piece automatically come out when you closed the lid?
