Lowest volume bar is too loud. How to lower internal volume on TV.
You can't but you can get round it. We have the same problem at work.
You have to stop using the internal speakers and buy a sound bar instead that provides more control.
There are a couple of ways of wiring a sound bar and the cheapest ones plug into the external/headphone socket and others plug into the coax, or component connections.
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
SOURCE: POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
SOURCE: have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
SOURCE: Sony Bravia Tv sound is too loud. the sound bar is
try opening the settings and lower the treble and bass it should get quieter but you may have to sacrifice some sound quality.
