When I power on my computer the screen for post up until the Windows XP Welcome screen has a Green background. Once the welcome screen comes up my display is normal. Also odd is the green is behind my windows wallpaper too!
I checked my cables to the monitor, re-installed my video card and checked for any errors and nothing has resolved this issue. I also scanned for viruses etc. which came clean.
Any ideas?
Sounds like a bad video card. Try putting a new video card in.
Try changing the desktop background to black .
to do this.
1 . right click on desktop.
2. select properties.
3. click on DESKTOP tab .
4. change color to black.
5. Apply settings . Ok.
Cause 2 . .... Sometimes it is possible that your cable is loose or is old ... Try changing your cable and c for the changes .
Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
If you have password protected your User account on your Windows XP system and can't remember the password(s) to Login. Whenever Windows XP is installed on a system, it creates a default account called "Administrator" and by default this account is not password protected. Therefore, if you bought a brand name computer (such as Dell, HP, Compaq or Sony)or you have installed Windows XP yourself. You should be able to Login to the computer through the Admin account.
Method One
Reboot your machine.
Press F8 before the Windows boot screen appears. Do not press F5 as used on the NT/9x ser of Windows. You will be be prompted with a boot options menu.
Select the Start Windows in Safe Mode option.
Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
The Safe Mode Welcome screen might display some of the other users on your system.
Login as the admin.
Press Yes at the prompt asking if you would like to continue using Safe Mode.
Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
Reboot your computer. As long as you don't press any keys (e.g. F8) during the boot-up the computer will startup normally.
Login as the user for which you set the password.
If the above doesn
What's odd is once the Welcome screen (Blue) comes up the display is normal. The video resolution and clarity is fine. It's only during boot up to the black screen with the windows logo.
