pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
This one requires more information. If the breaker trips randomly, then I say there is grounding problem between the plug and the freezer itself. I know the UK has a very large plug and it requires a serious connection into the wall. I would check and make sure you have a good ground on the box itself. You may have to removed the back and look at the connections If you have a V-OHM meter you can verify the ground through different parts of the freezer. If this never happen before and you just bought this freezer I would replace the breaker with a new one. The breaker maybe damaged and sensitive to heat from the current draw of the freezer. Also make sure it is the correct ampere required to run the freezer.
