Whirlpool RBS275PD Electric Single Oven Logo
A
Anonymous Posted on Sep 07, 2014
Whirlpool built in electric oven
While in the baking mode the upper element turn on causing the door to lock and over heat. I turn off the breakers and then reset the breakers and pushed the off button. This changed the display to pv2. The upper element was still on with the door still locked due to the high heat. I waited over night then reset the breakers but the upper element started to heat without the oven being on. The upper element goes on when ever there is power to the unit.
James Gettemy
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Nov 12, 2014
James Gettemy
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
131727
Points
821
The upper element is for broiling and should not come on until you tell it broil. If it is coming on as soon as you turn on the breaker then it sounds like the printed circuit control board is bad. There is a relay on the board that engages when you program in the broiler. The relay can be hard to find and may not be removable. My broiler would come on when I programmed in the bake mode, go into runaway heat, put up a F10 code, and shut off. I could not clear it until I programmed in the clean mode for 2 hours. Now it works great.
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Jul 09, 2008
SOURCE: The upper oven door is
im to assume that this happened while self cleaning, sonds as if you have had a high limit thermostat go bad adn has shut down oven function( depending on model there is also a fuse inline with the main control panel to protect it from the heat/ power surge, unit will need to be pulled out to acess fuse behind the unit
A
Anonymous
  • Posted on Aug 24, 2008
SOURCE: Whirlpool self-cleaning electric built in oven
I have the same problem. Who has a solution?
Anonymous
  • Posted on Dec 18, 2009
SOURCE: Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Anonymous
  • 43501 Answers
  • Posted on Apr 26, 2010
SOURCE: Upper oven heating elements will not engage.
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: From "bake" mode, oven door locked, both heating elements on.
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^
1helpful
Built-in electric oven jtp15w2ww gets to temperature then quits. No error codes.
If your built-in electric oven is getting to temperature and then quitting during a bake cycle, and the upper heating element is not working during the bake cycle but works on the broil setting, it is possible that the problem is with the bake element. Here are some troubleshooting steps you can take:
  1. Check the bake element: The bake element is the heating element located at the bottom of the oven. To check if the bake element is working properly, turn on the oven and set it to bake mode. Open the oven door and look at the bake element. It should be glowing red. If it is not, then the bake element is likely faulty and needs to be replaced.
  2. Check the oven temperature sensor: The oven temperature sensor is a small probe that is located inside the oven. Its job is to monitor the temperature inside the oven and communicate that information to the oven's control board. If the sensor is faulty, it may cause the oven to shut off prematurely. You can test the sensor with a multimeter to see if it is working properly. If it is not, then it needs to be replaced.
  3. Check the oven control board: If both the bake element and the oven temperature sensor are working properly, then the problem may be with the oven's control board. The control board is responsible for controlling the oven's heating elements and other functions. If it is faulty, it may be shutting off the oven prematurely. In this case, the control board will need to be replaced.
It is recommended to hire a qualified technician to perform these tests and replace any faulty parts to avoid any risks of electrical shock or damage to the oven.
Nov 23, 2022 • Ovens
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
1helpful
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
1helpful
2answers
Heating elements will not heat and getting an error code E1 F-5
Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Thanks
1helpful
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 • Ovens
Kenmore oven locked
Hello dktshopping,
I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
Upper oven bake coil stays on.
Stove will not turn offCHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately.ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
